Mberger19
May 07, 2020Aspirant
Orbi RBK23
I feel as though my devices in my house only try and connect to the router and not the satellites. If you get closer to one of the satellites, should the device automatically connect to the nearest sa...
Mberger19
May 08, 2020Aspirant
I have tried updating and there are no more recent updates to download. As far as the router is concerned, I don’t have a way of making it more central in my home due to connectivity. My main issue/concern is are the satellites supposed to show when I’m closer to them that I’m connected to the satellite or does it stay with the router no matter where I’m at in the house?
May 08, 2020Guru - Experienced User
You can update manually.
its not about being more central but it is about having them far enough apart. They need 30ft minimum between them or they won't roam correctly
