Shery999
May 11, 2019Aspirant
Orbi RBK30 additional satellite advice needed?
Hello everyone, so I have been looking for a mesh system for my home which is a bit larger than normal houses in UK. Its a three story old victorian style terraced house and the virgin superhub 3 jus...
ekhalil
May 11, 2019Master
Shery999 wrote:
....... will I be able to buy another orbi RBS40 AC2200 satellite (not the wall plug one) and connect it to the router of RBK30? Will they connect to each other?
Yes, you can buy RBS40 or RBS20 and add it as another Satellite in your network.
Good luck!
