mavericg
Jul 18, 2018Aspirant
Orbi RBK30 with NightHawk R8000
Hi. I just moved in recently to a 3-storey house and all this while I have a Netgear R8000 Nighthawk. i have around 200sqm of house and the Nighthawk can cover the entire house just that at the far e...
Jul 27, 2018Guru - Experienced User
Yes.
I would turn OFF the NH router if you have it still enabled while you set up and test the Orbi system out.
