gianniboynj's avatar
gianniboynj
Orbi RBK33 - need more coverage, can I add satellites or should I just buy a RBK753S-100NAS?
Hi All,   I purchased an Orbi RBK33 Kit (1RBR40 + 2 RBW30) a couple of years ago.  I have a 2 story home which includes a basement. Each floor is approximately the same size.  Inluciding my basemen...
  • CrimpOn's avatar
    Jan 24, 2021
    gianniboynj wrote:
    So, with that said, is it better to try adding a couple of satellites to "fill out" the week spots (i.e. not daisy chain) or should i just go ahead and buy something like the RBK753S-100NAS?
    This is an awkward time to invest in WiFi (i.e. spend a lot of money).
    A pair of RBS40V units would cost a little over $200 (Amazon). They integrate with the existing Orbi and could definitely expand the coverage area.  (The "voice" feature can be ignored or activated, whichever you want to do.)
    An RBK753 will set you back nearly $600 (Amazon).  It will almost certainly have a slightly larger coverage area than the existing Orbi and will definitely have greater "backhaul" bandwidth. It is more able to take advantage of the 1G internet link.  Whether it will actually create the desired coverage is conjecture. Great if it does.  "oops" if it doesn't. (More $$$)  Unless you already have WiFi6 devices (and almost none of us do), there will not be much difference in performance.
    This situation is even more awkward because the new WiFi 6E equipment is just coming on the market. Every manufacturer is annoucing (but not necessarily shipping) systems that can take advantage of the new 6G frequencies as well as the AX technology.  One problem with WiFi6 is that the 5G band has only two non-overlapping wide channels and some users  have found that every neighbor now has WiFi6 routers and there is congestion on the 5G band just as there is on the 2.4G band.  WiFi 6E features even more non-overlapping channels for backhaul.  Of course, there are no user devices that use 6E at all.  New WiFi 6E systems are going to cost even more than WiFi6 systems and there are no practical comparative reviews on them.
    So, spend $200+ as a "band aid" and prepare to replace the whole system in 3-4 years with WiFi6E?
    Spend $600+ (and hope the coverage is enough), and plan to replace the whole system in ?? years.
    Wait a few months and shell out even more for a WiFi 6E system that should last for a lot longer?
    You wanted advice, and got "what a mess." (I am sitting out the WiFi6 and waiting to see which WiFi6E gets rave reviews.)
