QQQQ
Jul 16, 2018Aspirant
Orbi RBK33 dropping WiFi Connection constantly - about ready to return it to the store!
I had a couple of routers in my home with separate SSIDs and finally opted to splurge and get a mesh system. Installation was rather painless aside from having to sort through how to port forward my ...
Jul 16, 2018Guru - Experienced User
Starting distances should be 30 feet to begin with between the router and satellites.
Try setting a manual channel 1, 6 or 11 on 2.4ghz.
Try disabling MIMO, Daisy Chain and Fast Roaming...
Try Advanced Wireless Settings both 2.4GHz and 5GHz changed CTS/RTS Threshold to 2307.
Was a full reboot of both router and satellites performed after all was updated?
QQQQ
Jul 19, 2018Aspirant
So far I've done the following
- Disabled MIMO, Daisy Chain and Fast Roaming...
- Set Advanced Wireless Settings both 2.4GHz and 5GHz changed CTS/RTS Threshold to 2307.
- moved the satellites farther apart
It seems to have gotten better with fewer dropouts but it's still dropping connections.
I'm reluctant to set specific channels on my 2.4Ghz as I don't know what else might be in conflict in my house or my neighbors so I think it's important for it to be able to select an open channel when necessary.
I didn't see any other suggestions from the community. Is this the best answer or might there be other things I can do to improve connectivity with my Apple products?
Thanks!
- FURRYe38Jul 19, 2018Guru - Experienced User
Download a free wifi analyzer and see what your nieghbors are using:
https://itunes.apple.com/us/app/network-analyzer-lite-wifi/id562315041?mt=8 Free
http://www.nirsoft.net/utils/wifi_information_view.html Free
https://www.acrylicwifi.com/en/wlan-software/wlan-scanner-acrylic-wifi-free/ Free
https://lizardsystems.com/wi-fi-scanner/screenshots.php
http://nutsaboutnets.com
