Mytherin
Dec 01, 2021Tutor
Orbi RBK352: (DNS?) Issues after restart
A few days ago I got my Orbi. I have set it up in AP mode. The Orbi is directly connected using an ethernet cable to my primary modem/router. Everything works well and the internet/connectivity is gr...
- Dec 01, 2021
Netgear has set up a community forum specifically for the Orbi AX (WiFi 6) products. Most of the people who watch that forum are more likely to have experience with Orbi AX and know how to work it better than those of us who follow this router forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-ax
Thank you
michaelkenward
Dec 02, 2021Guru - Experienced User
Sigh. Yet another person told to "go away" so that we can all chase our tails with a question that could have been answered here:
Solved: Re: Orbi RBK352: (DNS?) Issues after restart - NETGEAR Communities
Apologies for the clutter. But I didn't want anyone to come here following the SOLVED tag expecting to find a genuine solution rather than a rude boilerplate dismissal.
- FURRYe38Dec 02, 2021Guru - Experienced User
Well again, there is a specific forum for Orbi AX systems and yes, his problem and question was answer there. So please stop posting about "go away" posts and duplicating information and links. Posts are a curtesy message to let users user know there ARE specific forums for there products and questions that users can use and should be using. No "go way" context is meant or implied!
Specific forums are What they are there for!!!
Thank you.
michaelkenward wrote:
- michaelkenwardDec 02, 2021Guru - Experienced User
Only when you stop posting stuff that is less than helpful.
Keep doing it and I will continue to add my comments, which are designed to be helpful to people who have no idea how this place works and just want a quick answer.
It is not "courteous"
Spellcheck
to post unhelpful replies to questions easily answered where they are.
For your benefit?
