lbbasla
Mar 03, 2019Follower
Orbi RBK40怎么设置vpn?
rbk40在高级设置里可以用openVPN,但是不太会设置,提供的链接也下载不了客户端,有没有详细一些的教程
1 Reply
Sort By
- ekhalilMaster
lbbasla wrote:
How to set up vpn for Orbi RBK40?
Rbk40 can use openVPN in the advanced settings, but it will not be set up, the provided links can not download the client, there are no detailed tutorialsWhich OS do you need a clent for?
The setup is quite straight forward for smart phones (IOS and Android), and a little bit more sophisticated for MacOS and Windows.
The steps are briefly described in the web GUI as follows:
You need to use the links within the red box above to download the configuration files. There is a step-by-step description in the links within the green box above for each OS.
For Smart Phones you can search for OpenVPN in the App Store/Google Play. For computer OS's please see the links below:
MacOS: https://openvpn.net/vpn-server-resources/installation-guide-for-openvpn-connect-client-on-macos/
Windows: https://openvpn.net/vpn-server-resources/installation-guide-for-openvpn-connect-client-on-windows/
