rakserv
Aug 06, 2018Aspirant
Orbi RBK40 & RBS50Y Compatibility
I have an Apple Airport Time Capsule that provide good coverage for most of my house, there are a few dead zones that I have wired ethernet (1GbE) close to and i also have low signal and throughput i...
Aug 06, 2018Guru - Experienced User
You'll need to check with Apple to see if the Time capsule can be configured using LAN cableing. If it has a RJ45 LAN port, then I presume so.
The RBS50Y will connect to the RBR40 router for out door wifi support.
- rakservAug 07, 2018Aspirant
thank you for the information.
the apple time capsule does in fact have 1GbE RJ45 ethernet ports.
