napochan
Feb 10, 2021Guide
Orbi RBK40 AC2200 Portable Device WiFi Speeds dropped 80% with no deliberate change to system setup!
Wireless speeds of several portable (Android) devices recently dropped ~80% from previous speeds while WiFi speeds of a desktop and laptop have not. ISP service speed is 200 Mbps and this is mea...
napochan
Feb 11, 2021Guide
Agreed; that's what I did. I logged into the router to view the mapping of devices across the router, satellites and their assigned frequency band. I also read the assignments, signal strengths, and channel load in the Orbi app on a tablet and phone.
I will monitor the band assignments over time as I move through the house.
Is there a way to disable the bandsteering and lockdown a device to a band?
Feb 11, 2021Guru - Experienced User
No, with orbi there's no way to disable bandsteering.
its one of the challenges with mesh systems
- napochanFeb 18, 2021Guide
plemans, thank you for your comments. Large speed discrepancies also exist on other channels I tried and if I didn't mention it before, test results are also hugely different between Ookla's Speedtest and the Orbi app, when taken on my Android phone (moto g6).
There may be something amiss with my settings - although I believe the problem surfaced using default settings - but there seems to be a difference in how these apps measure speed. Results from multiple tests vary (as wireless signals are prone to do) but the magnitude of the difference remains the same.
Anyway, I'd be surprised if these observations are unique thoughout this community.
- plemansFeb 18, 2021Guru - Experienced User
You will get large discrepancies in speeds when using the orbi app versus using the speedtest app.
Reason why is when you use the orbi app, it hosts the test of the router. So its a hardwired connection.
When you use the speedtest app, its hosting off the device you're testing on. So if that device is wireless, the phone/tablet/etc that you're testing on is the limiting factor. Wireless isn't as fast as a wired connection. And 2.4ghz is slow as well. Plus if your device you're testing on is a 1x1 antenna device or 2x2 device. or any other issue that device might be having.
