richwoodUser
Jun 18, 2019Tutor
Orbi RBK40 (AC2200) Wifi Speed Issue
I have a Orbi RBK 40 (RBR40 and RBS40). Prior to upgrading my internet speed, I was getting 250 mb download on both wired and wireless. I recently upgraded my internet to 500 mb, however my Wifi sp...
Jun 18, 2019Guru - Experienced User
Disabling the wifi on the modem doesn't necessarily mean it's in bridge mode.
"I restarted everything multiple times including the router and cablem modem. " meaning that you just rebooted them or did you actually power them OFF for 1 minute then back on?
After updating FW, have you tried a full facory reset on the Orbi system and setup from scratch?
richwoodUser
Jun 19, 2019Tutor
Thanks for the advice. I tried tweaking the settings and can get the wifi speed occialliy above 250 now. I'll try a factory reset and see if that works. Thanks again.
- FURRYe38Jun 19, 2019Guru - Experienced User
Let us know how it goes...
richwoodUser wrote:Thanks for the advice. I tried tweaking the settings and can get the wifi speed occialliy above 250 now. I'll try a factory reset and see if that works. Thanks again.
