williamsdcx
Oct 29, 2018Aspirant
Orbi RBK40-AC2200
I have Orbi RBK40 running firmware 2.2.1.210. Ever since the firmware upgrade my MyQ Chamberlain Bridge (MyQ-965) and garage doors are not responding. I can open and close the garage doors through ...
Oct 29, 2018Guru - Experienced User
Are they showing as connected to the Orbi at all?
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually.
https://community.netgear.com/t5/Orbi/Firmware-2-2-1-210-and-connection-problems-Skybell/m-p/1649275/highlight/true#M43001
Advanced Wireless Settings both 2.4GHz and 5GHz changed CTS/RTS Threshold to 2307.
https://community.netgear.com/t5/Orbi/Orbi-RBR40-RBS40-V2-1-4-16-mesh-network-drops-connection-to/m-p/1601598/highlight/true#M35230
Change the CTR/RTS threshold values for both 2.4 GHz and 5 GHz (2341 and 2345 respectively), changed preamble modes to long preamble, and Set 20/40Mhz Coexistence to 40Mhz only.
Might see if this works any:
williamsdcx
IPV6 is also disabled.
