williamsdcx
Oct 29, 2018Aspirant
Orbi RBK40-AC2200
I have Orbi RBK40 running firmware 2.2.1.210. Ever since the firmware upgrade my MyQ Chamberlain Bridge (MyQ-965) and garage doors are not responding. I can open and close the garage doors through ...
williamsdcx
The MyQ Chamberllain bridge shows as connected to the Orbi. Also I can control the garage doors using the MyQ app just not home kit. MIMO, Daisy Chain are disabled. Fast Roaming is turned on. One of the Netgear reps had me disable Daisy Chain to give my system more stability since I have only one satellite running. (This was before update to FW.210)
Oct 29, 2018Guru - Experienced User
Is the check mark in the Daisy Chain or not checked? In this version of FW, the check mark needs to be on Daisy chain to disable it, as the behavior is reversed for some reason on this version of FW. However I presume this may not do anything.
I see others with Homekit issues on this version of FW as well...
- williamsdcxOct 29, 2018Aspirant
Thanks for the input on the reversing of the daisy chain function. I will check the box to disable daisy chaining until new FW is received.
- FURRYe38Oct 29, 2018Guru - Experienced User
Let us know if this helps any...
Chrcking the daisy chain box to disable the function did not improve the response of the MyQ Chamberlain component response. Since you are closer to this issue than I have been are our friends at Netgear working on a fimware upgrade?
