williamsdcx
Oct 29, 2018Aspirant
Orbi RBK40-AC2200
I have Orbi RBK40 running firmware 2.2.1.210. Ever since the firmware upgrade my MyQ Chamberlain Bridge (MyQ-965) and garage doors are not responding. I can open and close the garage doors through ...
williamsdcx
Thanks for the input on the reversing of the daisy chain function. I will check the box to disable daisy chaining until new FW is received.
Oct 29, 2018Guru - Experienced User
Let us know if this helps any...
- williamsdcxOct 29, 2018Aspirant
Chrcking the daisy chain box to disable the function did not improve the response of the MyQ Chamberlain component response. Since you are closer to this issue than I have been are our friends at Netgear working on a fimware upgrade?
- FURRYe38Oct 29, 2018Guru - Experienced User
I can only say that maybe reverting back to prior working version of FW may help. I don't have information regarding new FW updates.
