madballneek
Dec 06, 2018Initiate
Orbi RBK40 cuts my downstream speeds in half
As the title says, the Orbi RBK40 is cutting my downstream speeds in half (speeds checked by speedtest.net, Bing and Google speed tests and actual download speeds in various applications such as Stea...
- Dec 06, 2018
Throughput capped at 100 Mbps often indicates a bad cable or failed autonegotiaton between Ethernet ports.
Try a different cable between the Orbi and the cable modem.
Try a different port on the cable modem (if it has more than one port.)
Log into Orbi's Web interface and check the port speed on the WAN port. It's under Advanced, LAN Port, Show Statistics.
st_shaw
Dec 06, 2018Master
- madballneekDec 07, 2018Initiate
Looks like it was the cable between the modem and the router that was causing issues.
