trickylad
Oct 16, 2020Aspirant
Orbi RBK40 extending to garden room
Hi all. First post so thanks in advance for the help. I have had a Orbi RBK40 mesh for a few years. It's been brilliant. Like many others we're building a garden room and looking to get it con...
Mstrbig
Oct 16, 2020Master
I forgot to mention you can also use WIFI CPE to get WIFI to the garden room wirelessly. And possibly powerline adapters would work to get network capabilities there.
Either one you can plug the satellite into them and have your wireless mesh system extended to the garden room.
trickylad
Thank you.
What's a CPE?
- FURRYe38Oct 16, 2020Guru - Experienced User
Customer Premises Equipment
- trickyladOct 17, 2020Aspirant
Thank you FURRYe38 and Mstrbig
i've been looking around and wondering if getting an RBS50Y outdoor extender would be a better and simpler option? My garden room will have an Apple TV in it to run Zwift and a Sonos speaker but nothing else really. The cost and complication of running an Ethernet cable from my house (router is in the middle of the house, not next to a perimeter wall) isn't insignificant but i do have to put a power line in the ground anyway so it's not a totally binary choice.
You can get one of the extenders for £300 but I'd worry that i could wait , install it and it not be enough for what we need and missed the chance to have a wired alternative.
I have a RBK40 with one satellite upstairs that would probably be the bridge to the garden. The garden room is 35-40m away from the satellite - not really seen much about how far the outdoor extender will reach.
Any advice welcomed. :smileyvery-happy:
