Jetfree
Oct 14, 2019Aspirant
Orbi RBK40 Internet Disconnection Issue
Ever since the latest firmware update on my Orbi, I've been facing disconnection issue from internet even if the Wi-Fi connection is good. I see many posts on similar issue but none with a definite fi...
CrimpOn
Oct 14, 2019Guru - Experienced User
Oh, my. Netgear Hotline? Netgear provides telephone support for 90 days after purchase, and after that customers can purchase service contracts from GearHead: https://gearhead.netgear.com/ This is similar to Best Buy's Geek Squad, although one supposed they will have more expertise with Netgear products.
The Orbi web interface allows users to select which "Network Time Server" they want to use. On the Advanced Tab, Navigate to Administration, NTP (stands for Network Time Protocol). The key is that the user selects which "Time Zone" to use and whether Daylight Saving Time is observed.
Disconnection from the internet can be caused by a lot of things. Can you please describe:
- What is the Orbi router connected to?
Brand and model? - Is the Orbi in router or Access Point mode?
Thanks
- JetfreeOct 14, 2019Aspirant
Hi, the timezone is correct. Daylight Saving was already selected even if not applicable.
In any case, the date is indicating June 2019 which is outdated (even with the latest firmware installed).
What is the Orbi router connected to? ONT Optical Modem
Brand and model? Alcatel Lucent ONT. I don't know the model but picture is attached.Is the Orbi in router or Access Point mode? Router mode
Thanks
- JetfreeOct 14, 2019AspirantOrbi connected Alcatel Lucent I-240G-D running on router mode.
- FURRYe38Oct 18, 2019Guru - Experienced User
Modem Combo Units:
This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Jetfree wrote:Hi, the timezone is correct. Daylight Saving was already selected even if not applicable.
Thanks
- JetfreeOct 17, 2019AspirantHi, any advice?
- Retired_MemberOct 17, 2019
Jetfree wrote:
Hi, any advice?what firmware do you have and how did you get it?
- JetfreeOct 17, 2019AspirantSorry, I'm not able to check because my router cannot connect to internet anymore after the netgear helpdesk remotely changed my settings from router mode to access point mode. But I know I have the latest firmware downloaded through the web login. In fact, the helpdesk previously gave me instruction through chat channel to reinstall the firmware to resolve the problem but it did not help much.
- JetfreeOct 19, 2019AspirantOrbi connected Alcatel Lucent I-240G-D running on router mode.
- michaelkenwardOct 19, 2019Guru - Experienced User
So, you are running with two routers. You have already been advised that this is a bad idea.
Two routers on your network can cause headaches. For example, you can end up with local address problems. Among other things, the other router can misdirect addresses that the Netgear router usually handles, such as routerlogin.net or the usual IP address for a router, 192.168.1.1.
This explains some of the other drawbacks.
What is Double NAT? | Answer | NETGEAR Support
Unless you have specific reasons for using two routers – to create two separate networks for example – it is often easier to use just one router and then to set up the second router as a wifi access point. Netgear advises this, as does just about every site you will visit.
It may be possible to put the modem/router into modem only (bridge) mode and then to use the second device as the router. Sometimes it is easier to put the second router into AP mode. But that has its own drawbacks:
Disabled Features on the Router when set to AP Mode | Answer | NETGEAR SupportIn my case, I have put the Orbi into wireless access point mode.
- JetfreeOct 19, 2019AspirantI'm just perturbed why I never had this problem with my Asus AC87 router connected to this modem for the last 5yrs.
