MattShan713
Jul 15, 2019Follower
Orbi RBK43 - One Laptop Running Slow Wireless & Wired
Please bear with me. First time creating a post in a community environment. I purchased an Orbi RBK43 this weekend and set it up. Everything runs fine except for one of my laptops. Everything,...
Jul 15, 2019Guru - Experienced User
What model are these laptops and wireless devices? What model and mfr wireless adapter cards are installed?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
