LlamaLarry
May 28, 2020Luminary
Orbi RBK43 and Orbi Pro SRR60 Report Offline Multiple Times a Day
I have two networks with the same problem: 1. LB1120 + Orbi RBK43 2. LB2120 + Orbi Pro SRR60 + SRC60 Modems are both set to bridge mode and are hooked to external antennas. Multiple time...
May 28, 2020Guru - Experienced User
I would post about this in the mobile router forum. Seems to be a common problem with two different Orbi systems connected to same model modem.
https://community.netgear.com/t5/Mobile-Routers-Hotspots-Modems/bd-p/aircard
Good luck.
- LlamaLarryMay 28, 2020Luminary
I poste it there too to make sure I captured folks that are more familiar with the LB modems. Just seems weird that both my Orbi and Orbi Pro routers flake out. Is there a way to make the router re-poll the Internet connection from the Orbi app? Having a hacky solution of rebooting one or the other to fix the issue is pretty lame and takes some shine off of the mesh capabilities that an EOL hotspot cradle is able to work as expected.
