Viksharma
Oct 24, 2019Aspirant
Orbi RBK43 backhaul status poor
Hi I have a Orbi RBK43 system (2 satellites) running the latest firmware (.30 or something). The router is in router mode connected to a fiber modem The issue is one of the satellites always sho...
Oct 24, 2019Guru - Experienced User
My house is around 8000sqft but covered area is around 4000sq ft. The satellites are in two rooms - the farthest satellite is around 45 feet away in my main bed room which always shows good backhaul (although connection as per app is sometimes 5ghz and sometimes 2.4ghz). Now the satellite is around 40feet away but probably with more concrete wall in between.Thats you're key statement right there. Concrete and brick are amazing at blocking signal. A single concrete wall can reduce signal 53db and that put you at "poor connection" levels. I'm surprised you get a signal through concrete with enough to consider a usable backhaul. I'd investigate running an ethernet wired, powerline connection, or even a moca connection for the backhaul.
- ViksharmaOct 31, 2019AspirantThanks for the response but lemme tell you the throughput of the internet is same everywhere even with poor backhaul (my 100mbps Connection is shown 100mbps in both rooms when using speed test )
Maybe it’s something in my head that I want the system to show good backhaul as such the experienced throughput is great- FURRYe38Oct 31, 2019Guru - Experienced User
If your getting good thruput and speeds with the status reading poor then I wouldn't be too concerned about it. Again the system is dealing with concrete and this will impact the coverage. So even though the status reads poor, the system maybe working as best as it can with the conditions it's working with.
