Viksharma
Oct 24, 2019Aspirant
Orbi RBK43 backhaul status poor
Hi I have a Orbi RBK43 system (2 satellites) running the latest firmware (.30 or something). The router is in router mode connected to a fiber modem The issue is one of the satellites always sho...
Viksharma
Oct 31, 2019Aspirant
Thanks for the response but lemme tell you the throughput of the internet is same everywhere even with poor backhaul (my 100mbps Connection is shown 100mbps in both rooms when using speed test )
Maybe it’s something in my head that I want the system to show good backhaul as such the experienced throughput is great
Oct 31, 2019Guru - Experienced User
If your getting good thruput and speeds with the status reading poor then I wouldn't be too concerned about it. Again the system is dealing with concrete and this will impact the coverage. So even though the status reads poor, the system maybe working as best as it can with the conditions it's working with.
