spellfast59
Oct 01, 2018Aspirant
Orbi RBK50 - AirPrint Enabling
I'm using the Orbi RBK50 with NETGEAR DM200-100EUS. I've enabled my printer as an airprinter, it is not natively an airprinter, in netgenie. It worked once but now doesn't show on my ipad as an airpr...
schumaku
Oct 01, 2018Guru - Experienced User
Unless I'm very wrong, we need the desktop Netgear Genie (on either WIndows or macOS) installed to handle and offer Air Print on the network for non-native Air Print capable printers. Direct printing from the iOS devices using the mobile Genie App to the router USB port is not possible.
spellfast59
Thanks for your reply. I'm trying to print over wifi not via the usb port
