spellfast59
Oct 01, 2018Aspirant
Orbi RBK50 - AirPrint Enabling
I'm using the Orbi RBK50 with NETGEAR DM200-100EUS. I've enabled my printer as an airprinter, it is not natively an airprinter, in netgenie. It worked once but now doesn't show on my ipad as an airpr...
Oct 01, 2018Guru - Experienced User
What is the Mfr and model# of the printer?
- spellfast59Oct 01, 2018Aspirant
Dell 3115cn
- FURRYe38Oct 01, 2018Guru - Experienced User
This printer only has the following connection support:
10/100BaseT EthernetUSB 2.0 High SpeedIEEE 1284 Parallel PortThere is no wifi. I would recommend connecting the printer either ethernet or finding a wireless print server solution that you can connect the printer too that provides AirPrint features so you can print to it using that method or the PC method as suggested. I'm not sure if NG has any print servers, however I know HP does. Something to look into if your wanting Air Print support for your devices.https://tweaks.com/windows/46495/enable-ios-airprint-support-on-windows/
https://www.startech.com/Networking-IO/Print/usb-wireless-n-150mbps-airprint-server~PM1115UA
https://apple.stackexchange.com/questions/44237/are-there-any-airprint-compatible-print-servers
Hi
It is set up via ethernet not usb. The netgear software suggests that it can make a non airprint printer work as an airprinter hence my question?? Any ideas
- Christian_ROct 01, 2018NETGEAR Employee Retired
Hi spellfast59,
What FW is your Orbi router on? Do you have Genie, Acrobat reader, and iTunes installed on a computer? If so, are you able to print from your computer?
~Christian
- schumakuOct 01, 2018Guru - Experienced User
Christian,
Is there any current KB entry describing the exact requirements for Air Print to Netgear USB connected (only, correct?) non-AirPrint-capable printers? I understand iTunes (resp. the Bonjour package which was available for Windows back some time standalone) for the Bonjour stuff, Acrobat Read for rendering (?), and of course Netgear Genie for Windows or macOS. Last but not least of course also a working printer driver, configured to print to the (Netgear USB connected or any?) printer. Lots of variables.
TIA,-Kurt
Reference for AirPrint Setup: http://www.downloads.netgear.com/files/GDC/AirPrint/AirPrint_UM_EN.pdf
~Christian
