spellfast59
Oct 01, 2018Aspirant
Orbi RBK50 - AirPrint Enabling
I'm using the Orbi RBK50 with NETGEAR DM200-100EUS. I've enabled my printer as an airprinter, it is not natively an airprinter, in netgenie. It worked once but now doesn't show on my ipad as an airpr...
Oct 01, 2018Guru - Experienced User
This printer only has the following connection support:
10/100BaseT Ethernet
USB 2.0 High Speed
IEEE 1284 Parallel Port
There is no wifi. I would recommend connecting the printer either ethernet or finding a wireless print server solution that you can connect the printer too that provides AirPrint features so you can print to it using that method or the PC method as suggested. I'm not sure if NG has any print servers, however I know HP does. Something to look into if your wanting Air Print support for your devices.
https://tweaks.com/windows/46495/enable-ios-airprint-support-on-windows/
https://www.startech.com/Networking-IO/Print/usb-wireless-n-150mbps-airprint-server~PM1115UA
https://apple.stackexchange.com/questions/44237/are-there-any-airprint-compatible-print-servers
spellfast59
Hi
It is set up via ethernet not usb. The netgear software suggests that it can make a non airprint printer work as an airprinter hence my question?? Any ideas
- FURRYe38Oct 01, 2018Guru - Experienced User
This suggests the ReadyShare Utility:
Other Info:
https://www.netgear.com/support/product/airprint.aspx
- spellfast59Oct 01, 2018Aspirant
Thanks for the help so far. Can I be clear, I don't have any usb printers, They are all networked. So I want to use the wifi from orbo to print to my ethernet connected Dell printer - they're all on the same network.
- Christian_ROct 02, 2018NETGEAR Employee Retired
Thank you for the feedback. I will bring this request up to the necessary team.
~Christian
