RalphSparkle's avatar
RalphSparkle
Orbi RBK50 - are newer satellites compatible?
I have the Orbi RBK50 model and would like to buy another satellite (which I think are called RBS50).  They are hard to find at the moment.  Are later satellite models compatible?
  • CrimpOn's avatar
    CrimpOn
    I agree that the RBS50 is getting hard to find (and expensive if you do).  My "Best Buy" right now is the RBS40V which Amazon has been selling for $100. It includes a speaker for music (and Alexa), but that feature can be ignored if you want.
    Any of the original Orbi satellites will function with the RBR50 router: RBS50, RBS40, RBS20, RBW30, RBS40V, but NOT any of the "Pro" or "AX" satellites or the RBS10 model.
    • RalphSparkle's avatar
      RalphSparkle
      Perhaps a silly question - can the router act as a satellite too?
      (it's cheaper to buy a router and a satellite than just a satellite!)
      • CrimpOn's avatar
        CrimpOn
        Alas, no. Other companies designed their mesh systems to be identical, where any of them could be used either as the router or as a satellite. Netgear Orbi was not designed that way.  I believe there is a "hack" on the internet that will convert a router into a satellite.  I have never tried it.  But, if the router is essentially "free", who cares if it gets bricked?
        I have a second Orbi router that I bought off eBay to experiment with and to use as a spare.  Purchased in 2016, my original Orbi is LONG out of warranty.
  • I too am struggling to find RBS50 (in the UK)
    I'm disappointed Netgear aren't giving me a simple upgrade patch on a product that's only 3 years old
