Orbi1Kenobi77
Dec 30, 2017Guide
Orbi RBK50 - Inconsistent speeds and connections!
I have just bought the Orbi RBK50 twin pack and set it up. First thing I did was update both the satellite and router to the latest firmware - V2.1.1.16 I have now connected around 10 devices to...
ddp2049
Dec 30, 2017Aspirant
I see you are having a problem. How can you tell which devices are on the router and satellite? Do you know if the satellites' blue led light should be always on or it just turn at first connection?
Orbi1Kenobi77
Dec 30, 2017Guide
you can check the devices via attached devices page...
It is blue and status on admin page is good.
LED is irrelevant as I have mentioned that on some devices I am getting my maximum provider speed...
