Orbi1Kenobi77
Dec 30, 2017Guide
Orbi RBK50 - Inconsistent speeds and connections!
I have just bought the Orbi RBK50 twin pack and set it up. First thing I did was update both the satellite and router to the latest firmware - V2.1.1.16 I have now connected around 10 devices to...
Emperor1
Jun 12, 2018Guide
I've the same inconsistent wifi speed (and use a RBK23 kit with 2 satellites).
I'm using it as AP and the only change i've made is to enable Implicit BEAMFORMING
Have you solved the inconsistence ?
I use a 1GB fiber FTTH
