Orbi1Kenobi77
Dec 30, 2017Guide
Orbi RBK50 - Inconsistent speeds and connections!
I have just bought the Orbi RBK50 twin pack and set it up. First thing I did was update both the satellite and router to the latest firmware - V2.1.1.16 I have now connected around 10 devices to...
st_shaw
Jun 13, 2018Master
I have now connected around 10 devices to the Orbi and have noticed 2 main issues -
1. Some of the devcies that are positioned closer to the satellite are still connected to the router which is at a further distance...
2. I have performed speed tests from the same location (approx. 7 foot away) for two devcies, 1. Macbook pro 2014, 2. Ipad 2014
The Ipad maxes out my speed at 200mbps however the macbook is around 100mb!
I have then tested it around the hosue with my phones (android and apple) and a few other devices and I get mix speeds rnaging from 20mb - 120mb...
I have checked the admin page and it seems some of the wireless devcies are connecting to 2.4ghz network and others on 5ghz.
Why is it so inconsistent?Is there any settings I can change from default to help?
The only setting I have changed is disabling the Daisy-Chain Topology
The behavior you describe in 1) and 2) is not surprising. Some devices, laptops, IP cameras, OSX devices, etc. will not roam between access points (APs) until the signal becomes almost unsuable. They will stay associated with the first AP they see, even if a stonger AP becomes available. For these devices you must cycle the WiFi on and off to get them to connect to the strongest AP. Do that prior to your speed tests.
If some of your devices that do roam (e.g. iPhones) are preferring 2.4 GHz, then the device must think the 5 GHz signal is too weak. Next time this happens, use the Airport Utility on iOS to look at the RSSI for your APs. You might need to move the Orbis for better coverage, or you might need to add a second satellite. Lowering the Orbi transmit power on 2.4 GHz might help, but could reduce coverage area.
