slavrenz
Apr 08, 2020Aspirant
Orbi RBK50 - issues with Skype and other remote video services
Is anyone else having issues with Skype, Teams, Zoom, etc. running very poorly with the Orbi Mesh Routers? With the stay-at-home measures over the last month, I've noticed frequent issues with poor b...
Apr 08, 2020Guru - Experienced User
What is the Mfr and model# of the ISP modem/ONT the NG router is connected too?
Are the problems see over wired and wireless connections?
Please try a factory reset and setup from scratch with the RBR and RBS.
