jlkass
Jan 21, 2019Aspirant
ORBI RBK50 - Network is up but "Offline" - I AM LOSING MY MIND
I have an RBK50 that I have been using for a year. I have made NO changes. ISP is the same, the modem it's connected to is the same - literally NOTHING has changed.
Suddenly this weekend, it...
ekhalil
Jan 21, 2019Master
Can you login to the web GUI (orbilogin.com)? What is the status of the system in the GUI? Does Orbi have an IP address from the ISP modem?
You can get this information from the home page after you access orbilogin.com
jlkass
I was able to get there at one point, and it showed me that "no internet access" red badge. I just went back to check the IP and answer your questions and I can't get there at all. The iphone app can't find the Orbi now either. This happened before and it did eventually come back, but I can't tell you why....
This ran for a full year with no issues. I don't understand it.
- ekhalilJan 21, 2019MasterCan you please connect a PC to the LAN port on the router and use a browser to reach to 192.168.1.1.
What is the status of the LED on the back of the router and the ring on the top if the router?
