Swisso
Feb 22, 2018Tutor
ORBI RBK50 - RBS50 & RBS40 Drops wireless and wired connection
I have contacted netgear support teams and they go through the same list of things to try and it never works! I am quite technical so the steps they are asking are basic and need more advanced suppo...
mpf541
Feb 22, 2018Apprentice
Well the only way I made mine reliable is to downgrade the firmware to V2.0.1.4
And now I am just using as access point using the ATT for every thing else. Seems to be working properly this way.
And DMZ does not really work right with this modem. If you have IP passthrough on your ISP router use that
Feb 22, 2018Guru - Experienced User
THe DMZ differs on ATT modems from BT HUB modems. The ATT modems don't have FULL DMZ Features.
