cyberguts
Dec 02, 2019Aspirant
Orbi Rbk50 - WiFi devices not roaming correctly
Recently set up my Orbi RBK50, and everything was working brilliantly. Everywhere I went, I was getting 100% strength, and over 500mbps connection speed according to the WiFi Analysis section of th...
Retired_Member
Dec 02, 2019What has changed since the last time your Orbi was working fine?
- cybergutsDec 03, 2019Aspirant
Nothing has changed since it was good, only what I have changed to remedy the issue by changing setting like enable Beamforming, Fast Roaming, install Beta FW.
Retired_Member wrote:What has changed since the last time your Orbi was working fine?
