Marky-P
Jan 27, 2020Tutor
Orbi RBK50 - WIFI drop outs constantly
Ever since replacing my Asus RTAC87U with the RBR50 I have been having constant Wifi drop outs on all devices. I have observed on some devices including my S10+ and a Samsung Galaxy Tablet showing th...
Sundararamany
Jun 01, 2020Initiate
I've a similar problem with my S9+ and Laptop. The WiFi /VOIP calls keep dropping. esp moving from one room to another. There is no drop visibily on the WiFi itself and no issues seen with the static devices. If I disable WiFi, call on mobile 4G network functions without a problem. Appreciate if there are good troubleshooting guidelines to solve this.
Jun 02, 2020Guru - Experienced User
Sundararamany wrote:I've a similar problem with my S9+ and Laptop. The WiFi /VOIP calls keep dropping. esp moving from one room to another. There is no drop visibily on the WiFi itself and no issues seen with the static devices. If I disable WiFi, call on mobile 4G network functions without a problem. Appreciate if there are good troubleshooting guidelines to solve this.
