zannydu
Jan 29, 2019Follower
Orbi RBK50 & Circle - controlling an ethernet-connected PC?
Our Netgear Genie program on my laptop is super buggy (requires multiple logins, often does not show the Access Control checkbox, requires refreshing and restarting the softwear and/or the machines a...
ekhalil
Jan 29, 2019Master
You should be able to control both wired and wireless devices with Circle.
To find the devices go to the Main Menu from the home screen on the app as follows:
Then select "Devices":
You should see all devices that were ever attached to Orbi (even if they are not currently connected). Look for the device with the MAC address as the name can be different than what you named it in Orbi.
