cheesetrader
Nov 13, 2017Follower
Orbi RBK50 & RBS50 iPad vs Mac differential thru-put
We have a three unit Orbi setup (router + 2 satellites). Bandwidth thruput (c. 70mbs) is consistent at all points in our apartment (2200 sq ft) when measured on iPads. However, thruput on (two) Mac desktops (running 10.13.1 and 10.12.3) is variable and poor (10-20 mbs), and sometimes nil. Desktops are located near a satellite. Desktops register full bandwidth when moved to same room as base router. Can only conclude that there is some sort of conflict between the Macs and the satellite. Would appreciate any guidance re how to resolve! Thank you.
1 Reply
- DarrenMSr. NETGEAR Moderator
In the advanced- advanced settings-Wireless settings try un checking the 20/40mhz coexistence and make sure beamforming and MUMio are enabled see if that helps.
DarrenM
