GerardOz
May 14, 2020Guide
Orbi RBK50-100AUS, Cannot torn off 5GHZ
Hi All, Ive got a RBK50 modem and Satellite, new and the Fiormware is up to date. I've got an alarn device on 2.4g connected to it Ok. My Iphone needs to connect the device on the same 2.4g from wha...
May 14, 2020Guru - Experienced User
You can't shut off the 5ghz on it.
You can disable the ssid broadcast. Then try disconnecting your phone and reconnecting it.
There's been a few posts on this.
GerardOz
May 23, 2020Guide
Thanks for the reply, I found out it can only be reduced to 25% but that did the job.
Cheers
Cheers
- michaelkenwardMay 23, 2020Guru - Experienced User
For future reference, another ploy that has worked for many people when setting up IoT toys is to disable broadcasting of the 5GHz SSID.
It isn't the existence of 5 GHz that is the pain, but the fact that the setup process can be with a mobile app that connects to the 5 GHz. Poorly designed IoT apps can get their knickers in a twist when this happens. Force them on to 2.4 GHz and all works well.
