CNinBC
Nov 20, 2018Guide
Orbi RBK50 (1+2) Wifi Performance
I bought my RBK50 (1 Router + 2 Saterlites) from Costco, I noticed the wifi performace is inconsisitant from website to wbsite. General speaking, most of websites can be accessed normally via wifi/wi...
ekhalil
Nov 20, 2018Master
1. Can you please list the type of devices (wired and wireless) connected to your Orbi nodes?
2. What radio channels are you using for the 2.4GHz and 5GHz bands?
3. Do you have many neighbours with wifi networks? Which channels are they using?
4. Have you made a measurement from the Orbi app of the Intenet Speed? How is this compared to what you get from the other devices?
- CNinBCNov 21, 2018Guide
Thanks ekhalil for getting back to me, regarding your questions, please see my response below.
1. I got 18 5G connections, 8 2.4G connections & 8 wire connections
2. I set the channel selection to "Auto ( 8(P) + 4(S) )" for 2.4G and "36+40+44+48(P)" for 5G (i think these are the default settings)
3. I am not sure how to check which channel my neighbours are using
4. Internet speed on orbi app is 70/7 Mbps, while the speedtest software measured 69/6.4Mbps
Thanks.
