CNinBC
Nov 20, 2018Guide
Orbi RBK50 (1+2) Wifi Performance
I bought my RBK50 (1 Router + 2 Saterlites) from Costco, I noticed the wifi performace is inconsisitant from website to wbsite. General speaking, most of websites can be accessed normally via wifi/wi...
CNinBC
Jan 20, 2019Guide
I finally figured out what caused the network issue, it was my Cisco SPA 112 Voip Adaptor. Apparently, the QOS settings on RBK50 doesn't work well with SPA112, the SPA112 failed to connect to the SIP server and keep occupying the bandwidth. is there a way to adjust the QOS setting to make that work? the SPA 112 is locked by the service provider, I only can adjust the setting on the router side. thanks.
ekhalil
Jan 20, 2019Master
Currently there is no bandwidth control by device in Orbi.
Which ISP modem/router do you use? Do you need to have the VoIP adapter in the Orbi network? If not then you can probably move it and connect it directly to the ISP router if it has more than one port unless that you only have a modem or ONT?
