bariswheel
Sep 18, 2019Aspirant
Orbi rbk50 90% performance drop over 2-3 days, memory leak?
I found another post, it seems there are hundreds of people reporting symptoms where their 300Mbps connection drops to 30Mbps. Completely unacceptable known issue. I updated the firmware but I c...
bariswheel
Sep 22, 2019Aspirant
Screw it, I also put a checkmark in 'enable implicit beamforming'. The KB article says it's enabled by default, but it was disabled on mine, first time I'm seeing this so now way I turned it off.
dferreira1
Sep 23, 2019Aspirant
Hi,
I'm facing the same issue you have. The only option left for me is resetting the router to factory.
My router is a RBR40, 2.3.5.30 firmware version. I saw other people with same issue with RBR40, but got no solution to it.
A little brief about the issue:
I updated the router, everything went well. After some days I saw my network speed down to 10Mbps (file copying, inside the network wired to wifi ), I noticed that my wireless speed was something between 14mbps and 30Mbps... I rebooted the router and got 866mbps again. After few days (5 or 6 days) the wireless connection dropped to 10-30mbps again.
- FURRYe38Sep 30, 2019Guru - Experienced User
Did the factory reset and setup from scratch resolve your problem then?
dferreira1 wrote:Hi,
My router is a RBR40, 2.3.5.30 firmware version. I saw other people with same issue with RBR40, but got no solution to it.A little brief about the issue:
