thienthan
Nov 29, 2020Follower
Orbi RBK50 AC3000 keep disconnect
I even have the latest fw 2.7.0.70, but the problem keep happend every couple days or so. I read the thread on the forum to down grade back to fw V2.1.4.10. Problem fix. No more dis_connect.
Sort By
- vajimMaster
You fixed the problem by rolling your fw back?
IF your in the USA, then you can try this version of V2.7 at some point:
The first version of v2.7 seemed to be unstable.
Otherwise v16 is the most stable IMO.
thienthan wrote:I even have the latest fw 2.7.0.70, but the problem keep happend every couple days or so. I read the thread on the forum to down grade back to fw V2.1.4.10. Problem fix. No more dis_connect.
- vajimMaster
Or you could be happy with V2.1.4.10.
- vajimMaster
