captainhook88
Jul 10, 2018Aspirant
Orbi RBK50 AC3000 Wifi Speed always below 150 mbps
Hi,
I am getting weird download speeds on wifi on my new Orbi system. When I test my internet speed inside the Orbi-App, I get around 350-500 mbps down, 250 mbps up (I have a 500/250 mbps conne...
Jul 10, 2018Guru - Experienced User
You might either Forget This Network on the mobile devices or remove the wireless profile from OSX then reconnect to the Orbi SSID name.
in OSX you can Hold down the OPT key then click on the wireless radio icon at the top and this will list you more details of what wireless you connected too, mode, channel and other information. if you see that the Mac is connected to channel 1, 6 or 11, then it's connected to the 2.4Ghz radio. Channels 36 to 48 will be 5Ghz...
Would need to try and get a wired PC connecte to the back of the Orbi and see if your getting your 500Mb speed there as well.
Try the speedtest.net app on the iphones and ipads...
You can try disabling MIMO, Daisy Chain and Fast Roaming and see...
captainhook88
Jul 11, 2018Aspirant
Thanks again. I checked in the Orbi Web-Interface and it showed that my devices were connected to the 5 Ghz Wifi, so the issue should not be related to them wrongly connecting to the 2.4 Ghz Wifi.
I always test my speed by using the speedtest.net app on my mobile iOS devices, which gave me results of 80 mbps to 150 mbps (both up and down). However, in the Orbi-App, my router indicates speeds of up to 500 mbps.
I will also try disabling MIMO and Daisy Chain as soon as I get home (Fast Roaming does not change anything regarding speed, however, activating it, makes my devices switch more often, which is great)
I will try to get an ethernet adapter to be able to plug it directly into the router and see what speeds I get.
Is there any other thing I could try ?
Many thanks
- captainhook88Jul 11, 2018Aspirant
I now also spoke to customer support and they told me that I should have reset both devices to factory defaults after updating the firmware. I will do that as soon as I get home and report back.
