Jago3183
Nov 30, 2021Tutor
Orbi RBK50 and Now TV
I have been using my RBK50 router and satellite with a Virgin media router in Modem only mode without issue for the past 2 years. We are moving house and virgin is not available there and so are going...
Nov 30, 2021Guru - Experienced User
I would factory reset it to install it. That makes sure old settings don't cause issues.
And if the now modem can't be put in modem only mode, access point mode would be a good choice. You could also just put the netgears IP address into the Now's DMZ. That'd also work.
Jago3183
Nov 30, 2021Tutor
Thank you, much appreciated
