Jgag
Dec 20, 2021Tutor
Orbi RBK50 Blinking white and power light blinking
I have the RBK50 version with one satellite and last night sometime the wifi went out. Satellite unsynced and main router that I use as a WAP since att uverse only allowed it this way. The main box is...
Dec 20, 2021Guru - Experienced User
Unplug the RBR from the ISP modem and all other wired devices.
Power OFF the RBR. If you have a RBS50, use the power supply adapter from the RBS50 and plug it into the RBR50. Power ON the RBR with out anything connected. Does the back LED turn GREEN and remain ON or continue blinking RED?
What happens if you press the reset button for 15 seconds then release?
You have the RBR in AP mode?
Jgag
Dec 20, 2021Tutor
Yes it's in AP mode as it's been working since June of 2020. The power supply from the satellite didn't help as it's still doing the same thing. Holding the reset button doesn't do anything as well. No matter how long you hold it
- FURRYe38Dec 20, 2021Guru - Experienced User
Possible the RBR is bad.
Might try this:
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
Need to press the reset button for 30 seconds then release, then it send to PUT the command and upload the FW.
I had a problem on a Windows 10 PC where this didn't work to use TFTP, so I switched to a WIndows 7 PC and the TFTP worked.
Try nmrpflash:
https://github.com/jclehner/nmrpflash- JgagDec 20, 2021TutorI will be trying this later today and will report back. Thank you
- JgagDec 20, 2021TutorSo when setting up my IP address it is not saving as I still have preferred DNS and alternate DNS open
- FURRYe38Dec 21, 2021Guru - Experienced User
So you got access to the RBR? If so, I would do a reset on the RBR using the ERASE function under Advanced tab/Admin/Backup
Do this with the RBR disconnected from the ISP modem.
You might also download the RBR FW file and using a wired PC, re-load the FW file on to the RBR, after it's processed the file and back to ready, ERASE function, then setup from scratch using the setup wizard at 192.168.1.1.
https://community.netgear.com/t5/Orbi/Missing-Connected-Devices/m-p/2142349/highlight/true#M126110
