Len6
Dec 01, 2022Aspirant
Orbi RBK50 changing password for Security Options (WPA2-PSK) resort back to old password
I have a Orbi RBK50 changing password for Security Options (WPA2-PSK) resort back to old password. The router has firmware version V2.7.4.24. I have reset the router with the 3 methods suggested an...
- Dec 01, 2022
You'll not see much past 500Mpbs on 5Ghz AC. Due to limitations of devices, 2x2 MIMO and the design of the WiFi in general, will limit speeds seen. Also distances and environment noise and wifi neighbors will be a factor as well. You should see and can see near 900Mpbs on a ethernet connection with the RBR though.
Placement and distances between the RBR and RBS is key. 30 feet or more is recommended in between RBR and RBS🛰️ to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 🛰️One User Experience/Configuration:
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?
Dec 01, 2022Guru - Experienced User
Be sure to clear out all browser caches before entering the routers web page.
Try a different browser to see if you can effect the change...
Try a full on factory reset on the RBR and setup from scratch...
Len6
Once I did that, I am no longer seeing the old password. Thank you it appears it is now resolved. Do you have any idea about the reduced speed issue or if the numbers are normal.
- FURRYe38Dec 01, 2022Guru - Experienced User
https://kb.netgear.com/000062080/How-do-I-back-up-the-configuration-settings-on-my-Orbi-WiFi-System- Len6Dec 01, 2022Aspirant
Thank you, for the assistance. Closing this out.
