kbf1
Nov 12, 2019Initiate
Orbi RBK50 connect to 2.4GHz devices
I was all set to get the Orbi RBK50 2 piece mesh for my home. Can I connect with devices that are only 2.4GHz ? I have armacost Wi-Fi LED Lighting Controllers and Ring doorbell 2 with other devices. ...
- Nov 12, 2019
IF your having problems connecting 2.4Ghz devices to the Orbi you can temporarily disable the 5Ghz SSID broadcast while you get your 2.4Ghz devices connected to the RBR. Then re-enable the 5Ghz SSID afterwards.
michaelkenward
Nov 13, 2019Guru - Experienced User
Have you encountered problems setting up armacost kit? Or seen reports of real grief on that front? It does not seem to have come up here before.
As a search will show, many IoT devices have been through this, and, as CrimpOn and FURRYe38 say, there are straightforward ways of dealing with them. No need to disinter old hardware or faff around with modems.
With luck, the makers of these IoT toys will mend their setup routines to take account of the tact that the world is going Mesh.
kbf1
Nov 13, 2019Initiate
I will go ahead with the purchase and try this as follows:
I can confirm that this method does work with one additional step: V38 FW loaded.
@michaelkenward wrote:
- Turn off 5 GHz SSID broadcast. You must wait for about 1-1.5 minutes for the change to take effect.
- Pick up phone/pad.
- Go to wifi settings and tell it to forget the connection to the Orbi's SSID
- Turn OFF WiFi radio on the phone or pad for 5 seconds. Then turn the wifi radio back on.
- Tell phone to connect to the Orbi (it will see and use the 2.4 GHz SSID)
- Set up IoT thing
- Turn on 5 GHz SSID broadcast
- The next time your mobile phone connects to the Orbi it should find, and use, 5 GHz.
- FURRYe38Nov 13, 2019Guru - Experienced User
Hope you enjoy. :smileywink:
