newhall523
Sep 11, 2019Aspirant
Orbi RBK50 constantly dropping internet
Hello all, hoping I can get some help. I work from home, so depend on reliable internet connectivity. I bought this almost a year ago, but installed/set it up about 8 months ago. During that ti...
newhall523
Thanks for the quick reply. I will try your suggestions. What frustrates me is that it was working fine before over the past 8ish months. What happened literally over night?
The box and online ad said rbk50, but the ring is magenta. Not sure.
Sep 12, 2019Guru - Experienced User
The RBR is the RBR50 with in the box. Just making sure which ring you were referring too. The RBR which is the base router or the RBS which is the satellite.
Let us know about the suggestions.
