dsturdevant
Sep 07, 2017Guide
Orbi RBK50 Constantly drops Internet with Multiple Users V1.12.0.18 does NOT resolve permanently
To fix my Orbi system from dropping my Internet connection every hour I applied the latest firmware V1.12.0.18 and for a few months it worked perfectly. Nothing with the software or hardware infrast...
DarrenM
Sep 13, 2017Sr. NETGEAR Moderator
Hello Dsturdevant
We released the 2.0 firmware on the community you may want to try that firmware out and see if that resolves the issue.
DarrenM
dsturdevant
Sep 18, 2017Guide
Today was the first day I had multiple users on my network, three to be exact, since updating to the firmware and my Orbi dropped the Internet connection promptly after just 40 minutes. Then after a reboot it did it again about 1 hour later. Firmware version 2.0 seems to have had zero effect on my issue. When I am the only user on the network my Orbi NEVER drops the Internet connection. I'm far beyond the 90 days I had to return this product to Costco but I'm pretty sure I'll be throwing my 3 unit system into the garbage and going back to a reliable router. It's really too bad the solution to this problem seems to elude Netgear. With the router and 2 satellites my wifi coverage was signifigantly expanded. It just drops every hour.
- DarrenMSep 19, 2017Sr. NETGEAR Moderator
Hello dsturdevant
Our support team would like to work with you send me a Pm with your name, email, and phone number and I will have them contact you to try and resolve the issue you are having.
DarrenM
