Santhora
Sep 09, 2019Aspirant
Orbi RBK50 Data Transfer Speed Problem
Hello, I have one Orbi router (RBR50) and one Orbi satellite (RBS50) installation in my house. I've been having data transfer speed problem since the day I bought the product. All devices connected b...
Sep 09, 2019Guru - Experienced User
What are file xfer speeds with a wired connection?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
- SanthoraSep 10, 2019Aspirant- Wired connection works fine with full speed (110mb/s). Also i tried to connect my devices to Orbi satellite by wired and it works fine too. - My house is 1100 sq ft. But it doesn't matter. Because all devices were tested on the same table with the router. - All devices connected with 5GHz at maximum speed (866Mbps) - I also tried all 5ghz channels (36 to 48) - I tried the Beamforming, MIMO and WMM together or separately on or off. Note: I would like to say once again that i have never had such a problem with google wifi before. Is there any other suggestions I haven't tried?
