Santhora
Sep 09, 2019Aspirant
Orbi RBK50 Data Transfer Speed Problem
Hello, I have one Orbi router (RBR50) and one Orbi satellite (RBS50) installation in my house. I've been having data transfer speed problem since the day I bought the product. All devices connected b...
Sep 09, 2019Guru - Experienced User
What are file xfer speeds with a wired connection?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Santhora
Sep 10, 2019Aspirant
- Wired connection works fine with full speed (110mb/s). Also i tried to connect my devices to Orbi satellite by wired and it works fine too. - My house is 1100 sq ft. But it doesn't matter. Because all devices were tested on the same table with the router. - All devices connected with 5GHz at maximum speed (866Mbps) - I also tried all 5ghz channels (36 to 48) - I tried the Beamforming, MIMO and WMM together or separately on or off. Note: I would like to say once again that i have never had such a problem with google wifi before. Is there any other suggestions I haven't tried?
