Chunkers3161
Feb 02, 2020Aspirant
ORBI RBK50 disconnects internet
Hi there, I have recently installed ORBI RBK50 router and satellite and it has been working a treat, excellent connections, coverage and speed. Until ... we started to turn on/off certain devices or ...
Chunkers3161
Feb 03, 2020Aspirant
Thanks Furry ... I have tried disconnecting all wifi from the modem but I have not tried the bridging option. Will give this a go. Thanks again.
Feb 03, 2020Guru - Experienced User
Having two routers or two wifi sources near or on the same line can cause problems.
Hope the bridge feature will work for you, if not, try the 3rd Option suggested.
