marginaali's avatar
marginaali
Orbi RBK50 drops wireless connection when projector is switched on
My system is Orbi router + 1 satellite. 7 devices connected, everything works fine until I power on my projector (JVC X55). This causes the PC to drop connection in every ~5min, sometime more often, sometimes less. Wifi on all other devices continues to work. PC has a ASUS RT-AC68U wifi receiver.  Projector is connected through a HDMI cable through a Marantz receiver. If I switch only the Marantz receiver on there is no problem.
So there is some interference with the projector and PC wifi receiver. Any ideas?
  • FURRYe38's avatar
    Is this your projector?
    http://www.us.jvc.com/archive/projectors/allprojectors/dla_x55r/
    Is the ASUS running as a wireless brige for the PC?
    Can you test this with the ASUS bridge turned off and the PC connected by other means, different wireless or wired connection?
    How close is the projector to the satellites or Orbi router?
    Seems like this maybe a ASUS and projector issue...
    • marginaali's avatar
      marginaali
      Yep, that's the projector, no wifi.
      Asus is a PCI-card in my PC, internet signal comes through Zyxel VDSL modem (bridged) to Orbi.
      No chance now to test a cable, fairly sure it would work but not a solution because internet connection is so far from the PC.
      Projector is 3-4m away from the satellite, even further away from the router.
      Asus wifi receiver is close to graphics card so it could get interference from the HDMI cable leaving right beside it
      • FURRYe38's avatar
        I would try connecting the PC with out the ASUS adapter and see. Possible that something is coming in on the HDMI line. Find you a HDMI cable thats got good sheidling and ferrit beads at each end.
